1020/302 diesel engine problems
Bullfiddler
01-10-2007 08:28:31
Having some issues with diesel engine in a model 302. We just bought the tractor and was told that it was having some issues with fuel getting in the oil. I have read that there could be possibly a seal problem with either the fuel transfer pump or possibly the injector pump but this is where problem #2 comes. It is throwing alot of white exhaust smoke. I understand that this is usually caused by not burning all the fuel in the combust chamber. It does not have that much blow by and it starts fairly easy, even on a 30 degree day with no starting aids.
Could an out of time injector pump be causing both problems?
Bullfiddler
01-10-2007 14:05:47
 Re: 1020/302 diesel engine problems in reply to Bullfiddler, 01-10-2007 08:28:31
Thanks for the reply, my dad just talked to a local injection shop today and pretty much just repeated what you said.
jdemaris
01-10-2007 11:24:01
Yes. I assume you've got the D style pump, and not the C. 302 ought to have a JDB331AL2406. Roosamaster/Stanadyne pump gets worn, and #1 the brass bushing where the oil-seals ride gets worn - thus letting diesel fuel into the engine crankcase, and #2 the automatic timing advance stops working, so the engine is running retarded - which causes smoke and sometimes no-load high RPM skipping. You can easily check the timing advance with the engine running with a little plastic degreed timing window. Sounds to me it time to pull the pump off and fix it. A person with experience can go all through the pump in an hour or two (once off and on the bench). Parts should be around $50 unless something usual is found.
