Kurt: On the pits inside the rim, once you have them free of red rust, unless you don't like the look of them, but since the tire/tube will cover them, I would leave them unfilled. I apply a quality epoxy primer to the inside of rims. It will be so hard that odds are that nothing will ever rust in there again, as long as it is kept dry and without calcium solution in a tire, it should be. You can also paint the rim on the inside. If you don't use a hardener in the paint, it will take a long time before that paint is cured enough so as not to stick to the synthetic rubber of the tire bead and the tube. You can just leave them in epoxy primer, not your spray-it-from-a-can-from-the-hardware-store primer, I'm talking good, automotive type epoxy primer like PPG DP 40/90 or Transtar. Now you used the word "straighten". Is the rim crooked? Or is part of the bead lip bent (pretty common). If it is just a section of the bead lip, I use a combination of old body dollies that I bought at a flea market and a ball peen hammer that has radius on the peen ball that fits the correct inside radius of the wheel lip. Now you can use that as a guide and bucking dolly to form that lip back up, and the radius will be maintained. If you nick or ding it, file off the high spots, skim it with just a whisk of filler, sand it to form, epoxy prime, then paint. Now if the center of that rim if what is bent and out of true, you'd be better off looking for another rim. IMHO. Frank
