730 2 cylinder diesel
Larry Leger
01-09-2007 18:49:06
What is the difference between the crankshaft in the early 720 compared to the black dash 720 and the 730 diesel?
Blksmok
01-10-2007 10:54:57
 Re: 730 2 cylinder diesel in reply to Larry Leger, 01-09-2007 18:49:06
Larry.....the early 720D's used AF2193R cranks and the black dash 720D's & 730D's used AF3748R. The drive gear on the flywheel end is different as well as the main bearing housings and thrust washers. The newer crank uses the F3570 flywheel while the older crank uses the F1913R flywheel. Major difference in the thrust housing and all the parts inside that control crankshaft end-play. Got to be careful not to mix and match components in that area.
