AR Wiring
billde
01-09-2007 17:50:57
Have a 49 styled AR, have it running but the wiring is a mess. There are 2 pull switches, one on the lower right of dash, the other mid left. Which one is the kill switch? SM 2029 does not cover an AR nor a 12 volt A w/mag. Would someone have a wiring diagram for an AR with magneto?
Glen in TX
01-09-2007 19:22:32
 Re: AR Wiring in reply to billde, 01-09-2007 17:50:57
I can send you a diagram for the AR but it's basically the same as for the late A. Upper left knob should be choke and upper right knob shutter adjustment rod. Lower right should be light switch and if it came with a battery distributor would have a key switch above that. Most with a mag didn't have any kind of kill switch originally on the dash and you turned the fuel off at sediment bowl letting it run out of gas or if a all fuel AR it would have fuel selector valve and shut off control on dash to turn fuel off. All fuel styled AR is a little harder to find and has larger fuel tank and small gas tank while more common gasoline model has only one cap and tank. If mag has a kill terminal you can mount a kill switch on it but most people prefer to shut the fuel off to kill it. Check with Jim also at Agri Services for a new wiring harness.
billde
01-09-2007 19:47:10
 Re: AR Wiring in reply to Glen in TX, 01-09-2007 19:22:32
Glen, this one had a wire hooked onto the light switch to kill the mag. Switch is rusted in so I just ground the wire out on the tractor frame to kill it. If I were to install a new kill switch, what would be the best way to do it. I just had the mag rebuilt and don't want to damage it.
Glen in TX
01-09-2007 20:15:59
 Re: AR Wiring in reply to billde, 01-09-2007 19:47:10
Bill, That is not the way to ever hook at mag up to kill it. Magnetos produce their own power and should NEVER be hooked to any external battery voltage. Battery voltage on a mag will burn the points spring off and ruin condenser and coil and possible mess magnet up too. If you have the Wico XH there is a little spring lever with plastic button that can be put right on mag to kill it there or any toggle or push button switch that is self grounding on one side or can ground it with a wire on one terminal. I have some Murphy brand magneto kill switches that are momentary push button type we use on irrigation magnetos that work well too and mount on dash panel.
