JD 50 Distributor Uh Oh Now I've Done It
bills
01-09-2007 08:00:48
I broke the little plastic piece where the wire from the coil bolts on. Discontinued part from John Deere, nothing like it in any of my aftermarket catalogs. Has anyone else had this problem or am I the first dumby?
Randy G.
01-09-2007 13:24:15
 Re: JD 50 Distributor Uh Oh Now I've Done It in reply to bills, 01-09-2007 08:00:48
Going electronic is pricey. Coil $40, points near $100. OR I may have the PC you need off a Delco distributor #111558!!!!! I bought an extra distributor for my 49 B and wired it w/the electronic ignition and never used it. The B starts wonderfully w/o it still but replacing the piece you are talking about was replaced in the process. I kept the old connection. It includes both sides of the connector as well as wires. E me back or call if you"re interested in it. I can send you a picture if you like or call 641-932-8049. Randy G.
CENTAUR
01-09-2007 09:00:08
You do not need it.Just Go to points with the primary from the coil thru the hole of the distributor housing to the good like new points you have.Go to NAPA or other store & ask for a primary distributor lead often called (pig tail).After you pick the one that is long enough.Finally put some coulk around if neccesary to keep the dust etc.out. These kind of (pig tails)came with a molded rubber to fit usually in round holes. CENTAUR
ET
01-09-2007 08:54:31
Look at some other delco distributors. The 4 cylinder units used the same piece or very close to it.
machinery-man
01-09-2007 08:47:54
agree with other post, go electronic and you'll be much happier, however if you want to stay conventional, find a hunk of plastic and your dremel tool and you can fabricate without any problem...takes a little time but not hard to do.
buickanddeere
01-09-2007 08:15:28
Best thing that ever happened to you and the tractor. Now order a Pertronix conversion and coil from Kim here on this site. A set of solid core wires and Autolite 3116 plugs too while you are at it.
