Confused about manifolds for a later A
Dave in SV
01-08-2007 19:21:19
I could use some help understanding part numbers. My PC675 tells me that I need an A3386R manifold for my '49 A serial number 634007. Then again, it also says that the AA4543R is serial-number applicable. The AA4543R is an A4039R with studs.
I'm confused.
Can any of you guys explain? I may need another manifold, and want to be sure I get something that will fit!
Duane Larson
01-08-2007 21:24:15
 Re: Confused about manifolds for a later A in reply to Dave in SV, 01-08-2007 19:21:19
Dave,
The AA4543R manifold is a special manifold Deere provided to reduce carburetor and manifold icing problems in some climates, and is pretty rare. It is discussed in Field Service Bulletin 165, November 1949. I would just go with the A3386R gasoline manifold.
Dave in SV
01-09-2007 09:51:04
 Re: Confused about manifolds for a later A in reply to Duane Larson, 01-08-2007 21:24:15
Thanks, Duane.
I am inclined to agree with your suggestion that I stick with the A3386R... however, they're hard to find, and those that I have seen are cracked or have broken ears. Deere lists new for $400+, but I haven't confirmed whether they are still available or not.
Got any leads on a good used one?
Glen in TX
01-09-2007 13:21:43
 Re: Confused about manifolds for a later A in reply to Dave in SV, 01-09-2007 09:51:04
YT sells the new aftermarket ones as do lots of other vendors all over. adeptr.com (parts then state)
