JD 1010 Utility backhoe/loader
Richard Fazio
01-08-2007 10:00:58
I've got a 1010 backhoe loader. The power steering is basically non existant. It helps a very little bit when I have fluid in the pump. From what I can tell it uses a pump mounted atop the trans for the power steering. This pump I think is used for all the hydraulics on a regular farm version. This backhoe has a seperate pump for the backhoe and loader mounted up front on the crank. I can't get any help from JD on parts. They can never figure out what I have cause it's a utility. I would like to at least figure out if it's the pump or the steering valve that's giving me trouble. How can I check the pump for output. Does anyone know the pressure I should get out of this pump while running and not turning the wheels? will that work as a test? Is there a way to bypass the turning valve to get pressure to the cylinders to turn the wheels as a test? Thanks in advance.
