39 B coolant drain plug question
kevinjg
01-08-2007 09:48:25
i pulled out the pipe plug on the head to drain out the fluid to remove the radiator,the plug doesnt fit right its loose going in and leaks like crazy even with tape and paste.anyone know the correct size plug that should be in there?anyone have luck with loctite form a thread reair kit?
P Browning
01-08-2007 10:34:24
 Re: 39 B coolant drain plug question in reply to kevinjg, 01-08-2007 09:48:25
kevin -- My tractor had a fully worn out drain port to where you are now. I took the head to a machine shop and had them bore & tap the drain for 1" pipe, then went from there. You have a choice. Install a 1 x 3/4" sleeve reducer and then use the normal 3/4 short nipple & cap for the plug arrangement, OR go with a 1" short nipple and cap only! either way, you will be good for another 60 years!
If you do choose machining and tapping to 1", take a 1 x 3/4" sleeve reducer with you and leave it with the machinist. This sort of thing helps to ensure communications with your machinist as to what you want him to do!
There are many out there who will tell you to just run a 3/4" tap further into the hole, depending on the tapered nature of pipe threaders. That may also work for you -- as is suggested. You are the only one who is laying eyes on the problem, so you decide. (PatB)
mjbrown
01-08-2007 10:13:07
You might have to buy or borrow a pipe tap and tap it a bit deeper or go to the next size up with the appropriate plug. Those holes and plugs corrode so that the plug doesn't seal anymore.
F-I-T
01-08-2007 17:30:50
 Re: 39 B coolant drain plug question in reply to mjbrown, 01-08-2007 10:13:07
That what I do whenever possible. Borrow a pipe tap from the local plumber and since the thread is tapered, you'll likely only have to turn it one to one and a half turns and you'll have fresh threads the full length.
Frank
Tilar
01-08-2007 19:54:06
 Re: 39 B coolant drain plug question in reply to F-I-T, 01-08-2007 17:30:50
I ran a tap through the head on my 40 B, and instead of puting the plug back in, I installed a brass 1/4 turn ball valve.
Mike M
01-09-2007 09:06:12
 Re: 39 B coolant drain plug question in reply to Tilar, 01-08-2007 19:54:06
Gotta be careful with those turn valves ! My uncle did this on a working 620 and the corn stalks emptied it out and ruined the engine cause the gauge was also broke.
