1010 Starter
Poppy
01-08-2007 08:06:26
Does anyone know how to repair a 1010 gas starter with the internal solenoid? I just spent $90 at our local rebuild shop and it is back there now. This shop has been in business for many years, but parts are hard to find for this starter.
Is there no way that an external solenoid can be installed?
HTR
01-08-2007 19:25:41
 Re: 1010 Starter in reply to Poppy, 01-08-2007 08:06:26
John Deere dealer can give you two options to convert to Delco starter. JD rebuilt Delco TY6704, $161, $20 core charge. John Deere parts country/A&I Delco rebuilt TS1024, $113, $40 core charge.
jdemaris
01-08-2007 14:51:48
You can buy the solenoid kit right from Deere but the price is rediculous. You've probably got a Prestolite MDY-8006A. The contact-kit from Deere is AT17838 and priced at $150. I assume you could just hook up a remote starter relay, like many older Fords have - since the Prestolite only uses the contacts for switching power, not moving the starter-drive like the Delcos. But, any parts for any of the Prestolite units are expensive (Prestolie is now part of Leece Neville). In the long run, you'd be way ahead to get a used Delco starter and use that instead.
Poppy
01-08-2007 14:11:16
This is a gas tractor. This starter has been on this tractor for the past 20 years that I know of. It was rebuilt at my local repair shop several weeks ago for the same reason. Plenty of fire going to starter, but would not turn over. After the solenoid was repaired and I mounted it back on the tractor, it turned over a few times and then would only click. When I carried it back to shop Friday, it would only click on their tester. Evidently, there has always been a problem with this type starter with the internal solenoid. It seems to me that someway a straight hookup to the battery post on the starter would let you use a regular external solenoid. They tell me that it cannot be done.
Glen in TX
01-08-2007 12:37:47
Check parts catalog to see if you have the right starter or can trade for a different one. Gas or Diesel? The gas starters won't hold up or maybe not even work on the diesels. On your end you have the engine in time, good ring gear, good or new battery, good proper size cables, and excellent wiring and switches?
