JD 70
Internal Knock
Todd
12-27-1999 07:09:37
Thanks for all the info...Turns out that the flywheel and clutch drive are fine. Whoever did the rebuild used the wrong size connecting rod bearing inserts and they were excessively loose. Unfortunately one of them spun and stopped oil flow, (That made it audible!) At this point I've got the left side main bearing off and after a fair attempt at trying to coax the crank out am convinced that it has to come out through the right side. Am I correct about this? I do have an I&T manual but have decided that there might be a more thorough manual somewhere else.Todd
Scott
12-27-1999 17:05:11
 Re: JD 70 - Internal Knock in reply to Todd, 12-27-1999 07:09:37
Tom, you are right, the crank does have to come out the right side. I am not sure about another manual, the only one I have ever used is the I&T manual.
mark
12-27-1999 17:07:32
 Re: Re: JD 70 - Internal Knock in reply to Scott, 12-27-1999 17:05:11
you can order a repair manual from your John Deere dealer.
Steve Edwards
12-27-1999 22:14:49
 Re: Re: Re: JD 70 - Internal Knock in reply to mark, 12-27-1999 17:07:32
Deere manuals seem much clearer to me, but then I've read them for 30 years.
