JD 2010 will not start
Scott Moore
01-07-2007 05:27:01
My 1963 JD 2010 will not start. Started out changing points (Points set correctly), condenser, roder and distributer cap. Changed plugs. Even had the carb rebuilt. Even replaced the gas. I get it to turn over maybe once a day (very hard to get started), running rough and when I start to push the choke in she will stall out. After that it is a lost cause. Gas is flowing good. Once a day a go through the same thing. Some said that I may need timing rechecked but I can not figure out how to turn the distributer on this model. Seems to be all one unit going into the block. Never had this problem in the past and never had an issue with the tractor up to this point. I have just run out of options to try and look at. Would greatly appreciate any help that someone could give me
Thanks Scott
Scott Moore
01-09-2007 08:58:53
 Re: JD 2010 will not start in reply to Scott Moore, 01-07-2007 05:27:01
I am just getting back into this again and I have another question and comment. Carb was rebuilt, should I have it done again or can I do something like this. Second has to do with adjustments of the carb. What are the initial adjustments on these:
1. Throttle adjustment 1 1/4 turn ?
2. Low adjustment 1/ 1/4 turn ?
I can not find anything in the book on what the initial adjustments should be.
Thanks Scott
billde
01-07-2007 07:04:34
sounds like you may have dirt in the idle circuit of the carb. Clean the carb and put the old condenser back in. I also have a 2010, did all that you did, it would run fine for a few minutes and die. Drove me nuts, cleaned the carb again, no change, rechecked all elec components, no change, put the old condenser back in, it's ran fine every since. If you have a 2010, you don't have to worry about what to do in your spare time!
