1010 John Deere Coil Resistor
Poppy
01-06-2007 19:23:52
What size resistor do you need for a 1010 12 volt positive ground? Also, is it located before the coil or between the coil and distributor?
Poppy
01-08-2007 08:00:37
 Re: 1010 John Deere Coil Resistor in reply to Poppy, 01-06-2007 19:23:52
What would happen if you ran a wire from "start" on the switch directly to the coil along with the "run" wire that is already connected to the resistor? This would allow the hotter voltage to start the tractor and then run with less voltage.
jdemaris
01-07-2007 06:35:11
The original 1010 ignition resistor was built into the ignition switch. Sometime during the mid-70s, Deere stopped selling the original ign. switch and sold a change-over kit. Kit came with a new ign. switch, separate-mounted resistor and a few wires. One of the reasons Deere used the old-style switch was to accomplish a resistor-bypass for cold starting. 1010s came with Presolite or Delco starters and the Prestolites had no provision for a solenoid-type bypass - thus the switch with built-in resistor. Now, generally speaking about all the 1010 and 2010 gas engines - they need a higher spark voltage than many other tractor gas engines. Why - I can't tell you for sure - just not the greatest combustion chambers, I guess. So, Deere screwed around with relatively high-voltage ing. systems. 1010 uses the standard 6 volt coil from the older 420 two-cylinder 6 volt tractor, but uses it with a 12 V operating system. Even while running (not in cranking mode) the 6 volt coil runs on approx. 10 volts. This caused a lot of premature ignition-points burn-out problems - especially if the 1010 has the Prestolite distributor. We tried putting conventionally matched 12 volt coils and resistors on 1010s, but then there would be cold-starting problems.
John T
01-06-2007 19:55:39
Ideally, the ballast resistance is near the same as that of the coils primary winding (between its lil + and - terminals). On 12 volt tractors that use a 6 volt coil plus an external ballast, that would be somewhere around 1.5 ohms and typical ballast resistors are around 1.5 to 1.85 ohms. It (ballast) wires AFTER the Ignition Switch and BEFORE the coils input NOT between coil and distributor.
John T
