JD 'A' fluid levels
jd1952
01-06-2007 13:05:19
Could someone please tell me what the fluid levels/amounts are for a 1952 'A' (mainly oil and tranny fluid). Also, where are the correct spots to drain these fluids? thanks for the help
James Howell
01-08-2007 11:25:27
 Re: JD 'A' fluid levels in reply to jd1952, 01-06-2007 13:05:19
Agree with Pappy's description on all the drain plugs and fill plugs.
I used diesel to "flush/clean" both engine and transmission.
I changed all fluids on my 52A last month. Put 11 quarts of 30W in the engine. Oil level test cock on the pulley side starts to drip at 10 quarts. Added 1 quart for the new filter. Put 4 quarts of 30W in the PowerTrol. Put 1 quart of 30W in the oil bath cup. I use 30W because it doesn't get very cold in NE Texas.
Keep a close eye on the oil in the oil bath cup. I use a white work sock to cover the air stack. It keeps the dirt daubers out. Forgot to remove the sock and used the tractor all day. The sock had black patches where the air was sucked in. Doesn't take much to keep this oil clean.
I filled the transmission case with 90W up to the threads of the filler plug. It takes up to 7 gallons.
Topped off the radiator with antifreeze. Be careful with the antifreeze if you have barn cats. The "sweet" taste will kill them.
Hope this helps.
Pappy
01-06-2007 22:23:25
To drain the transmission/differential,there are two drain plugs on the bottom of the tractor. One will be a square head pipe plug and the other will be a 3/4 inch recessed plug. Both plugs should be removed to get all the oil out. Seven gallons. (get two buckets) To refill it, there is a pipe cap on the rear of the tractor to the right side and up from the PTO shaft. Both transmission and diffenential are one compartment.
On the bottom of the engine, there is a pipe plug to drain the engine oil. Also, there is a large cap about 4.5 inches in diameter that covers the oil filter. Remove both the plug and the cap. When you install a new filter, install a new rubber gasket ( O Ring). Tighten the filter cover just tight enough to prevent leaks. Don"t overdo it!!! In my "52 "A", I use 90 Wt. gear oil and 15W40 engine oil. Get your filter from your JD Dealer if possible. Lowest price I have found.
Sam in MN.
01-07-2007 08:12:22
 Re: JD 'A' fluid levels in reply to Pappy, 01-06-2007 22:23:25
Pappy,
I heard that you have to use straight 30W oil in the engine, with no Detergents. Detergents in the oil can cause permature wear on the cam. Is this an old wives tail or what? That 30W is pretty tough to get flowing some days and I worry about that too.
Thanks,
Sam
Dave in SV
01-06-2007 14:23:14
Engine 11 quarts. Cooling 8.75 gallons. Tranny 7 gallons. If you don't have an operators manual, get one... pretty inexpensive, and very valuable. John Deere OMR2001 C8. The I & T JD-4 shop manual is also a good resource to have on hand.
jd1952
01-06-2007 14:35:53
 Re: JD 'A' fluid levels in reply to Dave in SV, 01-06-2007 14:23:14
thanks for the help Dave
