John Deere D carb.
bigtim72
01-05-2007 21:58:34
what is the difference between a dltx 6 and a dltx 63 carb.? and will they both work on a 1934 john deere D? does the dltx 63 have the choke operated by a rod rather then the hand lever? and if yes can the dltx 63 be converted over to the hand lever style? or is the choke style to different? thanks for any help
bigtim72
01-06-2007 15:37:20
 Re: John Deere D carb. in reply to bigtim72, 01-05-2007 21:58:34
thanks for all the information your all so helpful I don't have any carb. right yet just located a DLTX 63 for $70 hoped it would inter change with mine sure it needs rebuilt so thought it be good time to change to the hand lever choke and check for gas nozzle
Glen in TX
01-06-2007 09:57:37
If you don't need the 6 sell it to someone that does. Yes, you can put the 63 on any D 31-53 and can even put it on a early D if you know what you're doing and can braze on another lever to reverse the throttle travel. The 63 was the last D carb made and works best with the gasoline nozzle Duane mentioned but it could have came with a all fuel nozzle also. The gas nozzle has more holes and longer with a tube soldered on side and slant cut on bottom end. They really run the best with those on gasoline as other carbs and nozzles were designed for all fuel and always need some fine tweaking to run better on gas. The 16 should be correct for your 34 though.
Duane Larson
01-06-2007 06:07:36
bigtim72,
The DLTX6 was a brass-body carb with an all-fuel nozzle and hand choke. It was replaced by the DLTX16, which was the cast-iron body version of the 6. The 16 was used with both the hand and electric start D. The 63 replaced the 16 at 161645 in 1945, and was the replacement carb for both the 6 and 16. Bob Beaver sells the correct hand choke www.robertscarbrepair.com and you might also want to make sure you have the nozzle designed for burning gasoline - he sells those also. They have a small stand-pipe on the side of the nozzle and are often interchanged with the nozzle in the DLTX51 on the styled G tractor.
Just don't try to put a carb on your D designed for any other model as the butterfly operation is reversed and the governor will not function correctly.
CNESLER
01-06-2007 05:46:43
BigTim
Serial number 109944-128110 use the DLTX-6
Serial number 161645- use the DLTX63
but the DLTX63 will work fine on the older models
and I believe that the choke can be manual or lever operated by changing the choke connector arm. Search for P Browning site He has some good information.
Hope this Helps
CNESLER
