A manifolds
Scotty H
01-05-2007 19:21:20
Are the Johnson, Heisler, and Jerry's cold manifolds for a 45 model A all pretty much the same thing?
Duane Larson
01-06-2007 05:54:50
 Re: A manifolds in reply to Scotty H, 01-05-2007 19:21:20
Scotty,
I don't know about Jerry's, but the Heisler and Johnson were similar in that they both had less mass than the all-fuel manifolds. They are different enough that they can be identified by look (and part number).
You want to be careful for the A in that Heisler made two cold manifolds - one for use with their high compression head (HA-12383L), and a manifold for use with the regular Deere head (HA-2383L).
Johnson Machine Shop went out of business in March 1967 and Hub City Iron Store in Aberdeen, SD bought the manifold business. They made them for several years, and since then several people have owned the patterns. I think most of the cold manifolds around now are based on the Johnson manifold.
Scotty H
01-05-2007 20:01:58
Thanks Glen. But I guess what I meant was are all the manifolds physically very similar.
Mike n Mo
01-06-2007 05:42:01
 Re: A manifolds in reply to Scotty H, 01-05-2007 20:01:58
The Jerry's manifold is quite a bit bigger in the intake runner than the other 2. The Jerry's and the Johnson have a straight intake runner, and the Heisler has a "S" shaped runner. Mike
Glen in TX
01-05-2007 19:49:37
Aftermarket reproductions of the Johnson cold gas manifolds been available for several years now again for A, B & G. Some just grind and port them out more. Heisler was not the same as the Johnson. Different companies.
Glenn Williams
01-07-2007 19:32:42
 Re: A manifolds in reply to Glen in TX, 01-05-2007 19:49:37
Where can I get johnson or heisler type manifols for a 1946 or 1949 JD-A
Glen in TX
01-07-2007 20:59:49
 Re: A manifolds in reply to Glenn Williams, 01-07-2007 19:32:42
I sent you email about them. YT has the Johnson ones on their parts on here and many other aftermarket vendors do also.
