70 remote cylinder change
DARYL G
01-05-2007 14:49:04
I HAVE THE POWER TROL UNIT OFF MY 70 TO CHANGE THE REMOTE CYLINDER PISTON O RING.I REMOVED THE PISTON BY TAKING THE CRANK ARM PINS OUT AND SLIDING THE ROCK SHAFTS OUT JUST A LITTLE. MY I&T BOOK SHOWS A HOLE TO USE AIR PRESSURE TO GET THE PISTON OUT. NOW IF I WANT TO CHANGE THE CYLINDER GASKET DOES IT COME OFF WITH THE REAR HOUSING? WILL ANYTHING FALL OUT THAT I NEED TO WATCH FOR. ALSO, HOW DOES THE PTO CLUTCH DRUM COME OFF? DOES IT JUST PULL OUT OF THE SHAFT THAT GOES TO THE MOTOR? WILL IT ALLIGN TO BACK IN? THANKS DARYL
Mike M
01-05-2007 16:52:08
 Re: 70 remote cylinder change in reply to DARYL G, 01-05-2007 14:49:04
Are you working on the pto and the hyd. ? If so you may as well go ahead and pull off the whole rockshaft housing. You support it with a chain and hoist then remove all the bolts and pull it off. Unhook the hyd. pipes first too. To get the pto clutch drum out you have to first unbolt and remove the pto pump which you will see after you pull that rockshaft housing off. A real good idea to replace the oil seals in the pump cover anytime you pull one apart. The rockshaft cyl. can also be removed once this assy. is off.
