HELP!!! 730 diesel (more info)
jed4020t
01-05-2007 11:09:33
the engine was completely overhauled. new crank, valves, rings, everything that I was told to replace by the local machine shop. this is one area where im not so sure about the source of advice. i had to rebuild the engine twice because of the mistakes at the machine shop. the tractor runs and starts easy. the injectors and the pumps were rebuilt and timed together by central fuel injection in IA. when i start the tractor and let it run for a couple minutes #1 exhaust gets hot #2 does not. running, it has never sounded right (i have been told by almost everyone that hears it) only under extreme load does it sound good. i am really looking for someone that i can take the tractor to because im about at wits ends with it. and i put too much time and money into it to be frustrated.
Mike M
01-05-2007 16:59:31
 Re: HELP!!! 730 diesel (more info) in reply to jed4020t, 01-05-2007 11:09:33
Another thing to check for is a cracked injector line. My cousins 720 developed a miss not long after the overhaul and he had a cracked line. Next ones we did we put in new lines right from the start as didn't want to ruin an expensive overhaul over those lines squirting fuel into the oil.
msb
01-05-2007 14:12:44
From where I sit, I would almost bet there is air in the fuel system. Those tractors can be a total bear to bleed.Just keep bleeding the fuel filters.I have seen the time it took a few hours of working the tractor and bleeding before that final little bubble came out the bleed hole, especially if the tractor has the pressure check valve on the fuel return line located on top of the rack cover.
F-I-T
01-05-2007 12:52:36
There is a real chance that #2 is not injecting the correct amount of fuel at the correct time, or not injecting at all. A 2 cylinder not hitting on #2 is tough for some folks to hear.
If you've gone through this much work, you no doubt have a service manual. Re-check the timing of the pumps. Be sure you use the timing mark on the flywheel that says "#1 INJ" and not the #1 TDC" which occurs at a different place. Then repeat for #2 INJ and see that the timing is dead on! If it is injecting late it could feel cool on that side of the manifold.
After you are certain that the timing is dead on, take the valve cover or top cover off (either one) and with the engine running, crack the pump to injector line nut at either the injector end or the pump end a quarter turn or so, just enough to make it lose its pressure and that cylinder should miss. If you do that to #1 and #2 is faulty, the engine speed will fall way down or it will stop all together. If it sounded all right with #1 dead and #2 running, switch it around and try it again. This will tell you if one cylinder is weaker than the other and point you in the right direction. From there you can switch injectors from side to side and isolate the exact component or adjustment problem.
If you were closer to Tallahassee, FL, we'd put it on the dynop and have a look see. Nothing tells the story like a few minutes on the dynamometer.
Frank
4010 Pride
01-05-2007 11:29:34
Do what WILAMABE said to do in the last posting. That will clear up your timing issue, because that definitely sounds like the problem. I have been there with my 4010 right after a full overhaul and a having the inj. pump rebuilt and it is not fun. Follow the manual to time it correctly. I am not a professional, but good luck.
4010 Pride
01-05-2007 11:21:58
I have seen them do that when they are out of timing. spit sputter smoke, put it on a load, it is fine. Take it off a load, spit sputter smoke again. My 2 pennies.
jddriver
01-05-2007 19:06:07
 Re: HELP!!! 730 diesel (more info) in reply to 4010 Pride, 01-05-2007 11:21:58
Dads 730 was doing that and gear pump above the clutch pulley was only putting out about15lbs.Got it up where it should be and it cured the problem.
