HELP!! 730 Diesel.
jed4020t
01-05-2007 06:13:47
Help me please!!! Been restoring 59 730 diesel for almost 3 years and I can't get it to run right. Doesn't seem to be getting good compression, engine completely overhauled. Located in western PA and I dont know who to turn to for help I tried all the Deere dealers, no good. Any assistance would be greatly appreciated.
F-I-T
01-05-2007 09:00:07
 Re: HELP!! 730 Diesel. in reply to jed4020t, 01-05-2007 06:13:47
You say it seems to be low on compression. As was suggested, a mis-set decompression lever can h9old valves partially open and make the compression very low ina hurry.
So, does it run?
If so, does it start hard?
Does it run equally well on either cylinder? (if you crack one injector line, and try to run it on the other? Does one cylinder seem weaker than the other?
Did you time the pumps correctly?
Has it had new rings/valves/guids/head work, etc.?
Need more detailed descriptions of the problems and conditions.
Frank
DONMYEIL
01-05-2007 08:34:42
WHAT DO YOU MEAN DONT RUN RIGHT? IS IT SHORT ON POWER,MISS FIREING ,SMOKING ? WHAT? ONE GUESS I HAVE IS FUEL PRESSURE TOO LOW. DOES IT HAVE THE HIGH PRESSURE SYSTEM. IF SO SHOULD BE 65 PSI ON THE FUEL FILTERS. LOW PRESSURE WILL MAKE IT DOGGY AND NO POWER, WILL SOUND LIKE A FLUTTER OUT THE EXHAUSE AT FULL THROTTLE WITH A LIGHT LOAD. THE HIGH PRESSURE FUEL SYSTEM DOES WONDERS FOR THESE TRACTORS. HAVE THE INJECTOR PUMPS AND NOZZLES BEEN BALANCED TO EACH OTHER?? HOPE THIS HELPS ,DON
Mike M
01-05-2007 09:46:11
 Re: HELP!! 730 Diesel. in reply to DONMYEIL, 01-05-2007 08:34:42
Your mention of low fuel pressure reminded me of a funny thing that happened with the neighbors 720D. He brought it up for me to do something or other ,maybe just change the oil ? Anyhow I start it up and run it all around up and down the hills for maybe 1/2 hour ? and all the while I can't beleive he never said about this thing being this low on power. I was a real dog ! But still ran normally otherwise no miss or smoke problems. I called him up and turns out he shuts off the fuel at the bowl everytime he stops it so it doesn't fill up the crankcase. (yet another problem )Here I was driving around with the fuel shut off. I still don't know how it ran so long ? It may of had some run in from the return line ?
Chuck430C
01-05-2007 10:05:36
 Re: HELP!! 730 Diesel. in reply to Mike M, 01-05-2007 09:46:11
I have heard the older fellows say that the 720/730 diesels were so economical, they would run for about an hour just by placing an oily rag in the fuel opening. LOL
I never tried it, but I know I burn less than 2 gallons an hour with a 6 foot brush hog mowing the fields.
One other problem that you discovered for him by accident is that his fuel shut off is not sealing, so he is not gaining much by shutting it off. If it sealed properly, you would get maybe a minute or so run out of it before it shut down from fuel starvation.
With more details, someone on here can diagnose his lack of power issue. Diesels are simple in that if they have good compression, and a spray of fuel timed properly, they are going to run and make power.
Mike M
01-05-2007 10:46:51
 Re: HELP!! 730 Diesel. in reply to Chuck430C, 01-05-2007 10:05:36
On the one I had I just turned on the fuel and it was back to normal. His internal leak of fuel to the oil was the delivery valve holders on the pumps.
GPULLER
01-05-2007 08:12:48
Another area to check is the decompressor linkage adjustment. Make sure the linkage is not holding the exhaust vales open.
It's beat to death but a service manual is a must for these diesels.
wilamayb
01-05-2007 06:35:03
Well there are sevral posiblities for your tractor!! How far did you take it apart? What makes you think it is not making good compression? If you took the engine completley apart there are sevral things I would check starting with the easiest like valve lash, then injection timing, then the relationship between the cam and the crank (did you line up the marks?). If you dont have one get yourself the service manual for your tractor. The service manuals are very complete, and will instruct you on the proper way to perform most functions on your tractor. The experts (not me) here will be able to better help you if you could give a description of what you have done to the engine and fuel system. A good description of the symptoms would also be very helpful.
