4240 Quad-range shift
Super Trooper
01-04-2007 20:37:43
I recently purchased a 4240 tractor. It as a Quad-range transmission. When in C range, it will pop out of gear. If you hold the shift lever in gear, it will stay. Is there an adjustment to the shift lever to keep it in gear or is it a bigger problem with transmission?
J.Stacey
01-07-2007 09:55:16
 Re: 4240 Quad-range shift in reply to Super Trooper, 01-04-2007 20:37:43
Check all linkage first. Could be in synchronizer on bottom transmission shaft.
01-06-2007 06:42:58
check on right side of tractor under cab..there should be a spring comes from cab down to range shifter.. should hook in cotter pin to cab...spring number is R56776.. hope this helps...have a nice day
MAY GOD BLESS THE USA
Maark
01-05-2007 13:20:50
Sometimes it's as easy to fix as making sure the cab mounts are tight.
