Help with worn Model A Pistons
Ravgardner
01-04-2007 16:05:25
The good news is I got the pistons out of the 44 A. But the bad news may out-weigh the good!!!
First: Wrist pins and the bushings are loose. The bushings will spin and come right out. Are there oversized bushings available? The oversized pins are listed in the parts book, but nothing on the bushings.
Second: The end cap on number one piston came off very hard. I'm not sure it will go back on. It looks like the bolts are pressed together a little. Should these be spread a apart some how? What do you suggest?
Three: The pistons are original ones. Is mother Deere the best place to buy the rings, wrist pins and bushings?
Mike M
01-05-2007 04:38:02
 Re: Help with worn Model A Pistons in reply to Ravgardner, 01-04-2007 16:05:25
I had an A with loose wrist pin bushing and the original was brass and the replacement was steel backed and fit tighter.
DickD
01-05-2007 04:10:54
First thing on the wrist pins, I would take the pistons to a machine shop and have the bushings made, and if you don't feel at ease fitting the pins, have them do it. I always fit mine with a brake hone WITH GOOD STONES. Next, on the rod bolts, I would put the nuts on the bolts and use a soft hammer to GENTLY spread the bolts to where the rod cap goes on easily. Neext and very important. check for ring ridge. If it appears excessive, then have a professional look at it and get his opinion on using oversize rings and honing the ring groove out, or boring the block enough to clean it up. I like using Deere replacement parts as much as possible. I think sometimes they are a little pricey, and that is when I go to the aftermarkets for parts. Hope this helps. Dick Dillman
