Well John, you're not home free yet. Those shims are used to set the lash of the governor shaft bevel gear into the fanshaft bevel gear, and you can't just throw shims in there and think it's set right. If you don't use enough shim, the teeth will bottom out and shell those teeth out in no time, so it is better, though not wiser, to use more shims than too few. At least with too much clearance you may have a noisy, rattly governor to fanshaft drive that will probably keep its teeth for a while. To set that clearance the right way, you would remove the fanshaft and the governor case and bolt them all together, then use a dial indicator to set the lash after adjusting the fanshaft front shims for proper heel. THEN, you should use some sort of rub indicator like Prussian Blue layout grease to see exactly where those gears are contacting. Just like setting up a ring and pinion in a car rear end. Again, to do this right, you have lots more work to do. Sorry. Frank
