4020 turbo rebuild
Mi 4020
01-04-2007 07:37:53
Hello All : I've go ta 1963 4020 D. that has a lot of blow by and starts hard in cold weather. I plan on doing a major on it this winter. Can anybody offer any thoughts on adding a turbo to this tractor at the same time ? I use it for everything except heavy field work including planting with a heavy planter, so I'm thinking I could use a little extra power above the anticipated std. rebuild. I would like not to modify the hood in any way to allow for the turbo but I don't know enough about the different turbo set ups to know what to shop for. this tractor has the power shift tran., does anyone forsee any problems if I do increase the HP 25 - 30 Hp?
Mi 4020
01-06-2007 09:32:34
 Re: 4020 turbo rebuild in reply to Mi 4020, 01-04-2007 07:37:53
Gentlemen..... easy now !!! This is the first time I have ever posted anything on a Forum for anything. It appears as though we have started to jump the track here a little, and some of you are spitting venim at one and other. First of all I appriceate the suggestions and ideas very much ! I am thinking from some of your comments that a std. rebuild without a turbo for now is probably the way for me to go. If I can get in the area of 105 - 108 H.P. I should be fine, if not I can add the turbo later. I plan on doing the rebuild myself so any issues of labor costs are basically non isues. I prefer to do my own reapirs for a number of reasons.. #1 I totaly enjoy working on my own equipment. #2 I don't farm enough acreage to justify large labor intensive repair bills. #3 Any time I've had work done through a J.D. dealership I get an estimate up front of $ 5000.00 to do the job , and then an actual invoice of $ 10,000.00 which gets a little hard to digest after a while if you know what I mean #4 In doing my own repairs, if it doesn't go well theres none to blame but me, and I don't find my self paying for a repair and then in some way finishing or correcting the job anyway. Buying a new or even slightly used tractor was a good sugestion in which I did research after it was sugested. However, because of costs and the fact that they just don't drive as well (in my opinion) as a 4020, I think for my dollars rebuilding my 4020 is a good investment. Besides with all the electronics on the new tractors it becomes difficult to diagnose any troubles without advanced equipment. Anyway, thanks to all for the input and ideas ! I may contact a few of you for some additional info a little later in the project. Thanks again !!
Gerald J.
01-06-2007 19:40:38
 Re: 4020 turbo rebuild in reply to Mi 4020, 01-06-2007 09:32:34
Be sure to have and KNOW the proper 4020 shop manual. And it wouldn't hurt to have a collection of Deere service bulletins on the 4020. There are two different shop manuals breaking at the beginning of 1969, the side console tractor beginning.
Its possible to mix and match parts and have them all fit and have the compression just a bit too low for decent starting. And its possible to let the valves get ground just a bit much and accomplish the same thing. Even going for a bit thicker heavy duty head gasket can cause that problem of hard starts from low compression.
Gerald J.
Mike M
01-05-2007 12:11:11
If you have been using it as it was, then after the overhaul it should give you alot more power and maybe even enough.
buickanddeere
01-04-2007 14:21:04
Price out how much the entire rebuild and mods project. Then double the cost and time required. Now wander on into the local Deere dealer and for the fun of it get a price on a 6603. Can't hurt to find out?
JDBert
01-05-2007 08:32:41
 Re: 4020 turbo rebuild in reply to buickanddeere, 01-04-2007 14:21:04
Suggested list on a 6603 2wd cabless 2-scv's 18.4x38's is over $37,000. A major overhaul done at the dealer will run about $1250 a hole- thats $7500- so thats a $29500 difference-
JDBert
01-05-2007 08:45:52
 Re: 4020 turbo rebuild in reply to JDBert, 01-05-2007 08:32:41
And if the old Ray-Jay turbo on your M&W kit needs work figure another $1500. So thats a $28000 difference.
buickanddeere
01-05-2007 13:04:22
 Re: 4020 turbo rebuild in reply to JDBert, 01-05-2007 08:45:52
So that's 10 grand to bring home a 42 year old tractor with everything worn out except for a refurbished engine??? $10,000 is better spent elsewhere.
JDBert
01-05-2007 13:46:14
 Re: 4020 turbo rebuild in reply to buickanddeere, 01-05-2007 13:04:22
Didn't ask about that now did he?? Not everybody has 4 times the money it would take to buy the 6603 over the 4020 either.
buickanddeere
01-05-2007 19:00:45
 Re: 4020 turbo rebuild in reply to JDBert, 01-05-2007 13:46:14
I can't afford new but certainly can not do business with equipment that costs more than what it's worth. If fixing old equipment really paid off and was cheaper. The skys would be full of DC-3's, 707's and trucking companies would have fleets of 318 Detroits still in use. And the typical personal vehicle on the highways would be a 60's or 70's vintage.
JD Jim
01-04-2007 08:50:19
I agree, 110 hp without a turbo is better setup.Dont know about early 404 but later side console models would do that just with fuel turned up. I have one that dynoed 115 hp after having pump recalibrated and new injectors.Otherwise stock with 4500 actual hours. If you want 125 hp plus look for a 4320. Just my 2 cents.
Mi 4020
01-04-2007 08:33:25
Thanks msb ! How did you typically get the 108 -110 Hp. ? Did you go oversize on the bore or just simply turn up the fuel injection ? Thanks
msb
01-04-2007 15:29:00
 Re: 4020 turbo rebuild in reply to Mi 4020, 01-04-2007 08:33:25
Just turned the injection pump up a bit.Usually only about 1/8 of a turn on the leaf spring screw.
msb
01-04-2007 08:26:04
I think you mean a 64 4020.I am not an advocate of turbocharging a 4020,even though I installed a slew of them years ago. That engine was simply not designed to take the extra heat and power a turbo produces. Only the early M&W Turbo kits necessitated cutting out the hood.You could be asking for trouble if you increase the horsepower 25-35%.I would not install a turbo without also installing a pyrometer and then shift down when the temperature go to 1050 degrees.I set a lot of 4020s up to 108- 110 horsepower and most customers got along fine with them.That was without a turbo and that is the route I would take if I were you.
Richard Graham
06-09-2007 13:33:21
 Re: 4020 turbo rebuild in reply to msb, 01-04-2007 08:26:04
Have a question I have a 1967 JD 4020 with a M and W Turbo when started oil is coming out of the tail pipe, is this a seal or bearing in the Turbo and can it be rebuilt and where can I get it done,,,,, , Thanks Richard
