IH Fella with a JD question
MJF
01-03-2007 19:53:19
Alright guys just so you know I am a red man, but we have as many green ones here on the farm so I'm around them but just prefer IH. This is my thoughts it might be way off or it might have a possibility. If you take like an A or G and I dunno if it's possible but it might be, move the spark plug to the center of the piston(like in the center of the head). That would prolly take some work but that should make a big power gain right? Then if u did that u would have 2 extra holes, if you could put a injecter type setup in there which would make it like a fuel injection setup. I know it's rough very rough but isn't the posiblilty there. I think that would make some big power for pulling. What do u green folks think about that
MJF
01-05-2007 08:34:22
 Re: IH Fella with a JD question in reply to MJF, 01-03-2007 19:53:19
I just thought it might have been worth a shot but I guess by the way you guys are talking it's not worth it..... .Hey drew who makes them heads
Drew
01-06-2007 22:52:57
 Re: IH Fella with a JD question in reply to MJF, 01-05-2007 08:34:22
Murphy's Motor Service, Hallsville MO. 573-696-3655
G heads will hopefully be available in a couple months, I do not know when the A heads will be ready yet.
MJF
01-03-2007 20:39:58
Oh so someone has done this, I meant to move them to the top of the head where the rockers are. Is that what you did, if so on what
Drew
01-04-2007 18:27:10
 Re: IH Fella with a JD question in reply to MJF, 01-03-2007 20:39:58
You can buy brand new cylinder heads with the sparkplugs in the head. They go in right under the valve cover and come into the chamber under the intake valve.
These heads are available for unstyled/styled A and the G.
Drew
01-03-2007 20:26:09
I have dynoed with the plugs in the side and the plugs in the head and didnt see a big difference.
B-maniac
01-04-2007 18:34:42
 Re: IH Fella with a JD question in reply to Drew, 01-03-2007 20:26:09
First of all fuel injection on a 1000-2000 rpm engine will gain you no power. It's not starving for fuel or even air for that matter. Secondly , on plug placement , an engine with the amount of volume above the piston as a 2cyl. JD has at TDC , doesn't have flame propegation problems like a high compression car engine does. It don't matter where the spark comes from , it has plenty of time and space to do it,s job. A car engine at 6000 RPM and 12:1 comp. , it will make a big difference. If you want large power increases in these engines , you need more stroke (and bore , but not as effective) and valve lift to feed the extra. Cam timing will enter in at some point but most people way over do it. Makes more sense to just tune what you have, perfectly, or go to the next bigger model if you want more power. A "B" isn't gonna last long making 40 or 50 HP or more and weighted down to pulling weight. When JD got up into the 50-60 HP range , they started using a third main bearing on the crank for a reason. Guess some have deeper pockets than others. Just my .02 and probably not worth it.
