Foot Brakes 1940 A:
Momsworry
01-03-2007 19:29:42
I have an old A that I recently aquired. This is my first JD so I am still learning things. The foot brakes work great when I apply them, but they stay applied unless I take my foot and pull back on the pedal to release them. Is this normal? I wouldn"t seem so. I have the IT shop manual and it shows a part just called "spring", that appears to go between the shoes, it looks as though there are two of them. Are these return springs, or what? If so, I suspect mine are either missing or somehow not placed in there properly or broken. Tell me if I"m on the right track here please. Thanks in advance for any responses.
donwisc
01-04-2007 10:09:07
 Re: Foot Brakes 1940 A: in reply to Momsworry, 01-03-2007 19:29:42
I have had a number of these assys apart and never found one that had a return spring. I have one apart now from a 38 A that has no provision for a spring.
The secret is to take the whole assy aprt and clean and lube all shafts and pins. The 2 pad springs will then provide all the force needed to return the pedal to neutral. Good luck
hardscrabble
01-03-2007 19:46:07
Yes, there is supposed to be a return spring on each pedal. But also the pedals should be lubricated where they pivot, either with oil or grease. My '49 A has the same problem. The springs are gone, so I have to manually pull back the pedals.
