4650 - stuck differential lock
Judd Gilpin
01-03-2007 16:46:05
My differential lock is not returning to the unlock position when I press the brake. The pedal to engage the differential lock does not move at all when I press it down.
Mike w J
01-03-2007 18:05:53
 Re: 4650 - stuck differential lock in reply to Judd Gilpin, 01-03-2007 16:46:05
Take the cover off of the dash and open the little window on the right side of the cab and look at the linkage it goes past center the wrong way .At least that is what happened to mine and it ended up breaking off the pedal pivot pin . That would be first place to look
Judd Gilpin
01-04-2007 06:10:21
 Re: 4650 - stuck differential lock in reply to Mike w J, 01-03-2007 18:05:53
Thank you both.
msb
01-03-2007 20:31:21
next place to check is remove the plunger in the top of the valve and replace the o-ring down inside.Plunger can get dirt in it or rust up so it will hang up on the o-ring.
