70 PS pump
BLinWMI
01-03-2007 16:41:42
Have a '53 70 that I have added a Char Lynn power steering unit. The unit uses a pump that mounts in place of the generator, then the generator is moved to the flywheel side under the air cleaner. Question is, could I put on a factory power steering pump, from parts available on ebay right now, and plumb it to the Char Lynn steering motor and expect it to work? I have done some looking and think that there is room to move the steering motor under the hood, between the LP tank and the radiator. If the JD pump would work with that steering motor, I could have a totally under hood PS system and the tractor would look factory from the outside. The after maket system is on and works pretty well but doesn't do much for the tractors looks. Any ideas appreciated
Mike M
01-04-2007 10:11:49
 Re: 70 PS pump in reply to BLinWMI, 01-03-2007 16:41:42
I would think the JD pump should work. An early one has a built in relief valve which you may NEED. I have also seen those steering units ran off a pump added in between the gov. and the dist. like the ones used to make live power on an A or B.
