4020 is GLOKENSCHPEEL!!!
66-4020
01-03-2007 15:08:31
pulled the oil plug for clues,,it has small flakes of brass or copper sitting on the drain plug,,I changed oil before it was on generator,wasnt no flakes then,,,otto
Glockenspeil/xylophone
01-04-2007 05:08:20
 Re: 4020 is GLOKENSCHPEEL!!! in reply to 66-4020, 01-03-2007 15:08:31
This Glockenspeil is the same as a Xylophone so I guess that means that 4020 is playing a tune of the Blues ?
Roy Suomi
01-03-2007 15:21:33
Brass or copper particles are an indication of a bearing or bushing going bad..Drop the pan and look around for a rod or main journal discolored blue or yellowish blue..If so there's your culprit..I'm not familiar with the 4020 series..Does that engine run a balancer assembly that runs off the crankshaft gear... The 3010 [ JD 500 backhoe ] ran such a balancer..There's quite a lot of rotating junk in that balancer..
Gerald J.
01-03-2007 16:25:54
 Re: 4020 is GLOKENSCHPEEL!!! in reply to Roy Suomi, 01-03-2007 15:21:33
No balancer in the 4000 series tractors. Only the 3010 and 3020.
Gerald J.
Glen in TX
01-03-2007 19:14:56
 Re: 4020 is GLOKENSCHPEEL!!! in reply to Gerald J., 01-03-2007 16:25:54
The clock is coming undone inside and the engines life is running out of time!
msb
01-03-2007 20:38:35
 Re: 4020 is GLOKENSCHPEEL!!! in reply to Glen in TX, 01-03-2007 19:14:56
Yup. Don't run it anymore that you just have to.Sounds like a major overhaul is in your future.Be sure to check the rocker arms for wear too.They are the first to run dry on oil.
