1939 B exhaust question
kevinjg
01-03-2007 10:56:39
im removing the wrong muffler from my b serial #76,625,the cast piece that mounts to the radiator has no holes for mounting anything its just a looped piece that the muffler went through,all the pipes im finding on web pages show a mounting flange that must be bolted to something what am i missing ?thanks ,kevin.
Maark
01-04-2007 13:19:25
 Re: 1939 B exhaust question-James greenmech in reply to kevinjg, 01-03-2007 10:56:39
What you're saying is correct on the muffler, but according to his post, he doesn't have the right radiator for that muffler. He will have to use one from a later B.
James Howell
01-04-2007 10:55:25
 Re: 1939 B exhaust question in reply to kevinjg, 01-03-2007 10:56:39
I agree with greenmech, the muffler on my 40B is welded to the flange that bolts to the top radiator tank.
The exhaust pipe on mine was "reduced" to fit inside the muffler.
Take a look at the B1313R manifold on eBay #
280066703273. It should be the same as on your 39B.
Hope this helps.
greenmech
01-03-2007 19:15:43
That type of muffler comes in one piece with the muffler welded to the casting.Detwilers in WI has them for your 38B 715-659-4252. Ron Mn.
Maark
01-03-2007 17:28:00
Parts book shows that the core is the same to ser# 200999. as far as the Hi-Lo tranny, it was used until Ser# 201000 when they used a single shift lever. The 39 and 40 B used a 4 speed tranny then in 1941 they used a 6 speed, both using the hi-lo lever. You might look at your manifold, there are 2 different exhaust pipes used depending on the position of the flange. 1 is straight across, the other is about a 45 degree angle. Detwilers in Wi. have those pipes for $40.00. Their parts book shows the pipe as the same from ser.#60,000-183971, and should have the holes straight across from each other.They have the mufflers as well. Check them out at www.detwilertractor.com
kevinjg
01-03-2007 19:11:36
 Re: 1939 B exhaust question in reply to Maark, 01-03-2007 17:28:00
thank you, i will go to that web site.
Maark
01-03-2007 11:47:27
Someone has replaced the radiator and used one from a later tractor.
kevinjg
01-03-2007 16:11:01
 Re: 1939 B exhaust question in reply to Maark, 01-03-2007 11:47:27
ok if you think that how do i tell what year it is ,im about to order a core and gaskets and what muffler hooks up to what i have ?
kevinjg
01-03-2007 16:20:50
 Re: 1939 B exhaust question in reply to kevinjg, 01-03-2007 16:11:01
the one i have looks just like one on ebay item 170066225287.that one is listed as a 41 that top piece is what i have and i dont know what muffler to use .im also questioning something else now did the b have a high and low choice on the trans in 1939?
