4020 gas gauge problem
BMAN
01-02-2007 18:51:19
My 4020 gas gauge isn't working at all. How do I tell if its the gauge or the sending unit?
BMAN
01-03-2007 04:57:19
 Re: 4020 gas gauge problem in reply to BMAN, 01-02-2007 18:51:19
Thanks for your help
JMS/MN
01-03-2007 00:05:48
Take the wire off the sender. Hold it to ground- it should peg the needle. If it does not, then replace the sender. Otherwise, replace the guage.
Gerald J.
01-02-2007 19:27:55
There two checks you can make at the sender. Its bolted into the side of the tank. Run a wire from a bare spot on the engine block to the flange of the sender. Its depending on the screws to make a ground where the gasket is an insulator. You can loose that ground. It that doesn't make the gauge work, then hook that wire to the wire from the gauge at the sender. That should move the gauge to the other extreme. If it doesn't then try that at the gauge on the terminal for the sender. Don't hit the other wire at at the gauge. Also check with that ground wire to see if the gauge case is grounded.
On my '68 gas 4020 the problem was that the wiper on the sender was worn out, and the pivots loose. I was about to bend the wiper so it works again. I had to take the sender out of the tank to work on it. A new sender would have been easier.
Gerald J.
