JD 60 trouble keeping it running
cwjohn
01-02-2007 11:49:10
I have a 1954 JD model 60 standard that after rebuilding the carb will not continue to run for more that a minute and I need to keep it on half choke to do that. It then sputters and dies. When its running it sounds great, no misfires, only a little grey smoke when it first starts. Any ideas?
johns48b
01-03-2007 06:43:08
 Re: JD 60 trouble keeping it running in reply to cwjohn, 01-02-2007 11:49:10
some of the experts will tell you what to do but you have some passages stopped in in the carb. go to JDHPubs.com and read up on the carbs. good luck
Mike M
01-02-2007 12:14:23
Does it have one of those automatic shutoff fuel bowls ? If so check to see if the little rubber washer is dropping down with the stem in the center and not sticking to the top. Check your fuel flow out of the bowl if it still doesn't flow enough like a pencil sized stream for a good while then you may have some junk clogging up the insides of the shutoff.
