MT Oil
Ken from Pa
01-02-2007 06:51:33
How much and what weight oil for a 1949 John Deere MT?
tstex
01-02-2007 11:57:21
 Re: MT Oil in reply to Ken from Pa, 01-02-2007 06:51:33
Ken,
Hayfarmer is correct on the quantity. The JD MT manuaul spec's out 20 weight, but that was a long time ago. Use a straight 30weight non-detergent...if she is real clean and does not have any "gunk", then a cleaning agent based 30 weight would be okay.
When you change the oil, make sure you replace the filter and also get a new rubber-ring gasket that sets at the base of the oil filter housing.
There is/was/or is suppose to be a metal washer on the bottom of the oil filter [for the older ones], but with today's filters, it is not needed.
Good luck,
tstex
Hayfarmer
01-02-2007 07:26:36
I use 30 wt oil year around, believe it takes 5 qts with new filter.
