38 B Governor
flying jd
01-02-2007 05:38:43
I have been having oil leak problems at fly wheel and from under governor and have noticed that end plate of governor housing (flywheel side) has a hole in it pointing up. Is this correct? Looking at pictures Of John T's B (absolutely beautiful) there does not appear to be a hole at all. I don't believe this is my problem but am about ready to remove governor and when it goes back I would like it to be correct. Any help or suggestions will be appreciated. THANKS
Jason Z in MO
01-02-2007 11:17:02
 Re: 38 B Governor in reply to flying jd, 01-02-2007 05:38:43
I know of a B which has a grease fitting installed on that end cover. The owner didn't think the governor shaft bearing which that cover supports didn't get enough lubrication so he installed a grease fitting. However, it was centered and perpendicular to the cover.
What is the diameter and is it tapped?
But your right, the factory didn't have a hole there.
flying jd
01-03-2007 04:22:32
 Re: 38 B Governor in reply to Jason Z in MO, 01-02-2007 11:17:02
The hole is perfectly centered on top of casting and is approx 1/4 inch, no threads. It looks factory but water would be able to get in when it rains this makes me believe it was not factory. The grease fitting sounds good as a temporary repair to keep water out.
