70D cyl. head
Grumps
01-01-2007 21:13:32
I have a 70D I read the casting # on head as F3211R which does not match my parts book #. Could someone tell me what I've got. thanks Joe
Grumps
01-02-2007 04:53:23
 Re: 70D cyl. head in reply to Grumps, 01-01-2007 21:13:32
Thanks Frank for the info,also does the F3211R head have the larger valves like the F3511R ? Thanks again Joe
F-I-T
01-02-2007 15:50:50
 Re: 70D cyl. head in reply to Grumps, 01-02-2007 04:53:23
I'm pretty sure it does. The valves called out in the 720D book are the same for either the F3211 or the F3511. I think the F3511 was a F3211 made to eliminate the injector sleeves.
The old 70D head used R57R intake and the F3214R exhaust, and the 3211/3511 used the F3213R intake and the F3214R exhaust. That got me in trouble when I ordered valves for my 70D rebuild, and the reason I have to unused R57R intake valves on my shelf.
Frank
buickanddeere
01-02-2007 16:24:58
 720 Re: 70D cyl. head in reply to F-I-T, 01-02-2007 15:50:50
Didn't Deere, knowing there was cylinder head problems with the 70D. They installed 720 heads on the 70's towards the end of the production run? I wonder what serial number this 70D is?
Grumps
01-02-2007 18:40:59
 Re: 720 Re: 70D cyl. head in reply to buickanddeere, 01-02-2007 16:24:58
Sorry Buickanddeere I miss read the ser. # it should have been 7033541 thanks again Joe
grumps
01-02-2007 18:01:30
Buick the serial # is 7083541 so it could be the 720 head from factary. thanks Joe
buickanddeere
01-02-2007 23:23:04
 Re: 720 Re: 70D cyl. head in reply to grumps, 01-02-2007 18:01:30
1956 production run of all model 70's started at 7031300 and ran to 7043757. That would have to be a fairly early 1956 model 70? Then again who knows what all has occured then and during the past 50 some years.
F-I-T
01-03-2007 06:46:19
 Re: 720 Re: 70D cyl. head in reply to buickanddeere, 01-02-2007 23:23:04
Glen:
Mine is 7033924 and it has the newer, 3511 head, so they must have cracked the original one.
I think maybe they came out with the 3211 for the 720 and immediately made it a field replacement unit for any 70D needing that part. But I'm just guessing there. I'm sure they probably tried to use the old style and then switch so they didn't have old ones in the system, but some dealers probably had them, too. Hard to say, but a lot of 70's have the newer head these days.
Frank
buickanddeere
01-03-2007 20:30:44
 Re: 720 Re: 70D cyl. head in reply to F-I-T, 01-03-2007 06:46:19
Dad's/my 70D has the 720 or 730 head but the part number excapes me and the tractor is an hour away. The origional head cracked and was replaced sometime in the late 1950's or early 1960's. Its serial # 7029119, a later 1955 model.Built June 6th and shipped June 8th.
F-I-T
01-02-2007 01:05:59
F3211R is the early 720 D heade that was used as a field replacement for the 70D. Later even the 720D head was upgraded to F3511R, which is now the option called out in the 70D parts books printed today.
Frank
Grumps
01-02-2007 17:56:47
 Re: 70D cyl. head in reply to F-I-T, 01-02-2007 01:05:59
Thanks again frank. This 70 pulls like it's breathing good so it may have the bigger valves. Joe
