JD 158 Loader
Musicman
01-01-2007 20:54:51
Does anyone know if a 158 Loader will fit on a
JD 5010 tractor?
Glen in TX
01-03-2007 14:22:26
 Re: JD 158 Loader in reply to Musicman, 01-01-2007 20:54:51
I too don't think the frame width is major concern but having the right bolt holes in brackets without having to modify much or any would be. Might also check on fitting up or looking at later and larger 265 and 280 JD loaders also. The 265 was made to fit 2940 MFWD up to 4450 2WD. The 280 with longer taller frame was recommended and made for 4050 MFWD up to 4850 MFWD and probably also 55 and 60 series tractors later as well. The later 158 loader was recommended for 4000 on up to 4620 and 4630 HFWD.
Mike w J
01-02-2007 12:33:27
I think a 168 loader will fit .That loader will fit a 4640/4840 The frame itself on the tractors are the same width as a 4440 But fuel tank and hood are wider . IT would maybe posible to put a 158 loader on a 5010 But the hoses and lines on the loader would have to be moved to the outside of the loader frame .
Glen in TX
01-02-2007 10:18:27
Never seen a JD loader on one before but have seen a local made green painted equipment loader at a dealer with large single cylinder on it. Also seen 5020 and 6030 with Farmhand or other aftermarket loaders you or someone else mentioned earlier.
JDBert
01-02-2007 06:34:34
Nope- you need a 168-
MSM
01-02-2007 07:46:24
 Re: JD 158 Loader in reply to JDBert, 01-02-2007 06:34:34
168 is a narrow frame loader also.
JDBert
01-02-2007 12:05:57
 Re: JD 158 Loader in reply to MSM, 01-02-2007 07:46:24
HUH- I've seen one mounted on a 5020 before and it was with JD mounts- so I dont know then I guess.
MSM
01-02-2007 01:20:09
No the 5010/20 are wide frame tractors. the 158 is for narrow frame such as 4020,4430,45/4620 etc.
