JD2030
Kalispel
01-01-2007 16:17:20
My 2030 quit moving while pulling hard in low gear.
The engine runs fine but no power is coupled through the transmission.
Each gear will engage and disengage without depressing the clutch. Gear meshing can be heard if the shifter is just eased into each gear.
It is a Hi-LO and it behaves the same regardless of the setting.
The clutch feels and sounds like it engages and disengages at the normal positon on the pedal. At low throttle a slight bump in engine speed can be heard as it disengages.
The independent PTO will engage and disengage and it will transfer power. But it now makes a soft clicking noise.
Any ideas?
Tx Jim
01-02-2007 03:50:14
 Re: JD2030 in reply to Kalispel, 01-01-2007 16:17:20
Does it have hyd hi-lo? If so hyd hi-lo clutch pack has failed or lost hyd pressure. Maybe traction clutch is gone. Tx Jim
