oil pump
Joe Daugherty
01-01-2007 08:20:39
Is there a new or rebuilt oil pump available for a 440 jd i can not find one Joe
Henry M
01-01-2007 14:10:49
 Re: oil pump in reply to Joe Daugherty, 01-01-2007 08:20:39
Joe
If ya want a good used one call the number listed in the next post above. Just a thought
buickanddeere
01-01-2007 09:09:13
Low oil pressure or busted pump? Excessive clearances maybe causing low oil pressure so a "new" oil pump will not maintain pressure either. If it was a Detroit there are various oversized oil pumps from 3-53's or 4-53's that will bolt under the 2-53's front cover
Joe Daugherty
01-01-2007 09:42:46
 Re: oil pump in reply to buickanddeere, 01-01-2007 09:09:13
I just completley rebuilt the engine the oil pump is worn and not pumping enough I need a new or rebuilt pump but can't find one It is a 440 gas engine same as a 430 pump. Joe
