JD 60 70 Power steering problem
lynn herring
12-31-2006 18:29:51
Would like help with steering problem. The power steering needs adjustment, but I don't know where the adj. valve is. Have a JD Service manual on both tractors but they do not address PS issues. Both tractors will turn the wheel by itself while idling. The 70 has gotten so bad I can't turn the wheel to steer it sometimes. The PS pump pulls the steering wheel out of my hand. Can anyone give me some pointers. Thanks...
Glen in TX
12-31-2006 19:44:05
 Re: JD 60 70 Power steering problem in reply to lynn herring, 12-31-2006 18:29:51
Like Frank says most have worn parts causing the problem. Seldom does loosening and bumping the lower pedestal around some for alignment fix it. For the manuals holler at Ed 812-537-4622 or try JD 800-522-7448. Manuals like the SM2050 Power Steering, SM2011 Hydraulics and others are listed as Tractor Accessories service manuals by JD Publications.
F-I-T
12-31-2006 19:30:10
LS:
It might be a whole lot more than an adjustment. The 70 that pulls the wheel from your hand is indicating a stuck actuator valve and that requires some, albeit simple, surgery.
The first thing you really need to lay your hands on is either the special, power steering system manual published by Deere, number SM2050, or the I&T manual for your tractor, which does a succinct, but overall decent job at explaining the theory of operation and adjustments.
Now, that run-on sentence aside, the symptom of the wheels turning one direction, hands off, indicates to me that the actuator valve assembly box is sitting either too far forward, or too far aft, that is to say it is not centered, so that the actuator valve is porting pressure oil to one side of the rotary cylinder. It could also be a piece of broken component or other debris holding the actuator valve in a forward or rearward position. That does happen.
The good news is that your pump must be working and the rotary cylinder is operating, but I can't say how much leak-by there might be.
It would take the length of a bible to explain it if you don't have a book of some type or access to some illustrations. You could learn a lot and see some pictures if you run a search for "power steering", as this topic has been discussed ad nauseum for at least the last five years.
Once you get a handle on the system, you'll be able to narrow your problem to two or three suspects and then I or others would be happy to go into detail at that level.
Frank
Gary U in CA
01-01-2007 07:23:30
 Re: JD 60 70 Power steering problem in reply to F-I-T, 12-31-2006 19:30:10
Frank, you are the man!
BTW, Chuck was very appreciative of all the material you provided, thanks my friend.
Hope your having a wonderful holiday.
Gary
F-I-T
01-01-2007 09:18:05
 Re: JD 60 70 Power steering problem in reply to Gary U in CA, 01-01-2007 07:23:30
Same to you, Gary! Did you get your power steering problem figured out?
Gary U in CA
01-02-2007 17:57:33
 Re: JD 60 70 Power steering problem in reply to F-I-T, 01-01-2007 09:18:05
Haven't had a chance to tackel the 820, gotta get the Oliver off the maintenance pad 1st.
Hope you had a great holiday, drop an email when you get a moment or two.
Gary
machinery-man
01-01-2007 04:46:18
I would say that you have worn bearing in the worm assembly thus allowing easy pressure against the valve. That valve only has to move a fraction to allow oil movement. There are several wear areas in the whole system and it appears that the last thing folks did was to perform some maintanence adjustments along the way. It does sound like you have a good pump. Get the manual and go to work. Good luck.
F-I-T
01-01-2007 09:21:46
 Re: JD 60 70 Power steering problem in reply to machinery-man, 01-01-2007 04:46:18
That could be true, but he needs to go through the entire checklist of verifying worm bearings are good, the worm endplay is to spec, the sector engagement is correct, and then I'll bet he finds worn pins and cam faces on the actuator sleeve that are hanging it up, or dirt or a chunk of relief valve spring stuck in the valve. ;)
