1949 B leaking gas
Ohio Smitty
12-31-2006 12:40:09
I just purchased a 1949 JD B. It's been sitting in a barn for the last 2-3 years. The owner said it runs, so we charged the battery and had to rebuilt the mag to get it to fire. It fired right up after that. After I got it home I put it in my barn and I was messin' around with it, changed the plugs and put in new gas. Now when it's running it is leaking gas, looks like out of the valve cover bottom right side and also out the bottom inside of the clutch pulley. Also a few drips out the bottom plate next to the flywheel. What does all this mean. Does the head need to be rebuilt? It seems to run ok except for that. I turned it off immediately after that.
teddy52food
12-31-2006 16:27:06
 Re: 1949 B leaking gas in reply to Ohio Smitty, 12-31-2006 12:40:09
If you have the button above the bulb, there are oil lines there too, right? I think there is your problem. The gas is filling the crankcase from the tank through those oil lines.
Ohio Smitty
01-03-2007 16:17:16
 Re: 1949 B leaking gas in reply to teddy52food, 12-31-2006 16:27:06
Teddy, I wanted to thank you for your professional advice on the automatic shutoff with the oil lines. I took it apart and replaced the diaphragm's and the rubber washer in the bowl. The old diaphram's were worn really bad and had holes around the edges. The cost was only $7.37,this is my first JD B and I'm learning alot already. Thanks again.
machinery-man
12-31-2006 15:23:44
that is extremely puzzling. That model was not supposed to have the automatic shut off. Anyway the shut off is bad and needs rebuilding or replacing and you needle valve is leaking. If I were you I"d replace the shut off with the factory manual shut off. Then check the carb. Don"t crank with all the fuel as you will hydo lock the engine and could seriously damage expensive parts....
fixerupper
12-31-2006 18:04:19
 Re: 1949 B leaking gas in reply to machinery-man, 12-31-2006 15:23:44
Machinery Man, believe it or not, an automatic fuel shutoff is listed for the B in the factory parts book. I didn't think it was available until the numbered series. Happy new year! Jim
Ohio Smitty
12-31-2006 17:48:51
Thanks for all the info, I will drain oil and replace oil and filter. I will also check for factory shutoff and rebuild carb. This tractor was my wife's uncle's and his uncle bought it brand new and I'm pretty sure the shutoff is original, the serial# is 237973. Thanks for all the help and Happy New Year..... .....
Kurt_JDB
12-31-2006 15:21:11
I had the same thing happen to me one time when I forgot to shut off the gas. I couldn"t even turn over the engine because the cylinders were full of gas. Might want to pull that sucker out of the barn so you can safely drain everything. This would include draining the first reduction gear cover as well as the crankcase. You might try opening up the petcocks and see if gas pours out. As machinery-man said this is a very hazardous situation.
In my case, the float in the carb had a hole in it, and so it filled with gas, wouldn"t float and close the needle valve. A new float, needle and seat fixed that.
Kurt
Ohio Smitty
12-31-2006 14:17:34
There is no shut off, there is only a buttom on top of the glass bowl that can be depressed to let gas flow to the carb.
machinery-man
12-31-2006 14:02:50
BE CAREFUL!!!!! !!!! you"ve got a dangerous situation. Your needle valve is not seating, you didn"t turn off the gas and the crankcase if flooded with fuel. Shut you gas off and drain out the oil....change filter...new oil, rebuild carburator or at least turn off the gas. Be sure not to have a spark around your situation.
