4620 brakes
MK
10-29-2003 18:03:04
When I apply the brakes to turn it makes a grinding noise. If I touch the pedal lightly there is no sound but if I'm in soft ground I have to push much harder to make a turn and then the noise is there. Is this normal or is there an adjustment to make or...??? I have 7200hrs on it.
John Jenkins
10-30-2003 20:02:14
 Re: 4620 brakes in reply to MK, 10-29-2003 18:03:04
Both of our 6030s do it. Always have.
joe
10-30-2003 09:32:26
Every 20 series tractor I have drove(at least 10) all have made noiss when turning to the LEFT, and using the LEFT brake only to assist. I have no idea why they do this, but all the mechanics I have talked to say that noise when using only one of the brakes to turn(usuallly the left one) is some what normal for these models and not a concern. I ahve no idea why that is, but i wouldn't worrry about it if that is the case. If you have noise all the time when using the brakes I would have that checked out. If you aren't sue find someone near you who knows these tractors and ahve them drive it to see what they think. Experienced drivers of the 20 series tractors can usually easily tell if everything is normal by driving and listening.
Good Luck
JDBert
10-30-2003 06:28:06
ours does the same thing and has since we bought it in the early 80's. We've been in the rearend on ours and everything looked good.
david val
10-30-2003 00:27:04
check asap the screen and the bottom of the transmission for brake lining remains. if it's clean, the most common cause for brake chatter is improper oil. oil properties may be deteiorated by adding wrong oil or mixing oils by use of implements shared with other non jd tractors.
fresh approved oil may eliminate or reduce chatter when the brake linings are ok.
david
720Deere
10-29-2003 18:40:53
Everybody's "grinding noise" is a little different. We have a 4320 that has had a brake growl ever since new. I have been told that the 4620 does the same thing. The brakes on those new generation tractors seem to last almost forever, but at over 7000 hours your grinding noise could be more than the normal growl. From your description of needing alot of pedal pressure to make the noise, this sounds exactly like the characteristic growl that our 4320 has.
MK/720Deere
10-29-2003 21:01:08
 Re: Re: 4620 brakes in reply to 720Deere, 10-29-2003 18:40:53
I'm probably not describing the sound right for lack of a better word, but growling might be closer. This didn't just start recently, it's been ever since I bought it about ten yrs ago. It doesn't "grind" as in a metal on metal sound.
720Deere
10-30-2003 05:33:17
 Re: Re: Re: 4620 brakes in reply to MK/720Deere, 10-29-2003 21:01:08
I have never heard of a 4020 doing this, but every 4320 that I have ever been around does it. I think there was a post on here a few months ago about the same thing. You may want to search the archives for more information (good luck on that one!). If it has always done this then it is probably the same old noise that is within character for these old beasts! Maybe Gman could be of help on this one.
Steve - IN
10-29-2003 18:13:30
MK,
I've been enough of a cheapskate (not to say that you are, just me) to wear shoes/pads down to the nubbins a few times. They make that same grinding sound when you wear away that soft material and get into the hard backing material (can't say asbestos, might get sued).
Guess you're gonna need to put in new soft material on the brake or stop using the brakes.
