2440 correct front tire size
creekfarmer
12-31-2006 09:30:31
When I bought my used 2440A, the previous owner had installed Super Swamper truck tires on the front rims. I want to go back to the original 3-rib old style tires. Does anyone know what size tire it should have? It's a 1981 model S.N. 366082T.
Any help would be appreciated.
creekfarmer
01-02-2007 06:16:51
 Re: 2440 correct front tire size in reply to creekfarmer, 12-31-2006 09:30:31
Gerald:
Thanks for the reply. Actually, I have an owners manual and a parts manual. However, they both list several sizes and I have no idea which rim I have. I know it is a 15" rim and it appears to measure about 5-1/2" inside diameter. The Super Swamper truck tires on there now are size 31X10.50-15LT and they are 4-ply nylon.
Here are the 15" sizes listed in my manuals:
27/9.5-15" 10-ply or 6-ply
7.5L-15" 6-ply
9.5L-15" 6-ply
11L-15" 6-ply
If there are any tire guys out reading this forum, I would appreciate your suggestions. Again, I am trying to replace the front tires with what came on the tractor when it was new.
Thanks,
Allen
Gerald J.
01-02-2007 08:42:07
 Re: 2440 correct front tire size in reply to creekfarmer , 01-02-2007 06:16:51
ANY of those sizes could have come on the tractor when it was new. Depends on what was ordered. Wider and taller for loader service for sure. Small and skinny for a cheaper purchase.
Measure the rim width at the tire beads. Those 31 x10.5s are probably on a rim 8 or 10 inches wide. The 11L15 is a good fit on that rim. You want the inside dimension, but measuring outside will work just you subtract two metal thicknesses from the distance between the parallel parts outside the tire beads. Don't measure the curved parts.
7.5L would be on a 6 or 6.5" rim, 9.5 on a 7 or 8" rim.
Look for the Goodyear Farm Tire Handbook on line. Google should find it. It did a few months ago. It has a table of tractor fronts (I like 4 rib for work rather than three rib) and another table of acceptable rim widths for those tires. Its the rim width at the beads that determine the optimum tire. One presumes that the rims came with the tractor originally. I know that's not true for my 4020 because I changed them and they aren't yellow. But I wanted the floatation for a loader on a smaller tractor them moved that loader to the 4020. I went a little overboard but I gained cultivation and spraying clearance with the 11.00-16.
With the Goodyear Farm Tire Handbook read, you will know MORE than most tire dealers. Titan and Firestone have them too, but the Goodyear handbook is the easiest to find on line.
The rims will tell which tire (and there still may be a choice to make depending on your finances). With those 10.5 there now I'd lean towards the 11L15, but with a tractor tread not a wagon tread unless you want a turf tire because the wagon tread doesn't grab dirt well. I know because I did that with 11L16 wagon tires on my tractors before I went to the 11.00-16 on the 4020. When rotary hoeing the wagon tires would take 30 feet to make a course correction and that was sometimes hard on the crop.
Gerald J.
Gerald J.
12-31-2006 10:14:56
Get thee an owner's manual. It will list the original options that I suspect included 7.60-16, through 11L15 or 11L16 with different rims. You will find many other useful hints in that manual to allow you to make better (and safer) use of the tractor.
Gerald J.
