Correct tap size for manifold studs?
David275
12-31-2006 07:40:27
After removing the maifold on a 1953 JD 60 I would like to clean tap the threads before reinstalling. From what I can tell I should use a 3/8 14 tap, but I can't find one. Is 3/8 14 the correct tap, if so where can I get one?
F-I-T
12-31-2006 09:10:53
 Re: Correct tap size for manifold studs? in reply to David275, 12-31-2006 07:40:27
third party image
Looks like the inner portion uses 3/8"-16 fasteners, while the outer uses 7/16"-14 fasteners.
Frank
P Browning
12-31-2006 08:24:05
David -- go to your parts catalog and look up the studs. Hopefully, their diameter is given and I would imagine it to be in the neighborhood of 7/16 inch and this being the case, the tap needed to chase those tapped holes would be 7/16-14. The thread count for UNC (coarse) is 3/8-16, 7/16-14, and 1/2-13 -- this FYI -- widely available such as on Google, etc.
