Rockshaft housing for a 4040 needed
57ringo
12-30-2006 18:47:05
I have a 4040 that the rockshaft housing is leaking between the swivel fitting and the little pipe plug above it. It appears to be cracked there. I replaced the oring twice before I noticed it was leaking above the swivel fitting. What causes this? The housing from a 4040,4240 & 4440 are the same according to deereparts.com The housing part # is AR74108 and housing with bushings is AR69959. Anyone have a parts tractor that doesn't want an arm and a leg for this housing?
Pat
57ringo
12-31-2006 07:46:36
 Re: Rockshaft housing for a 4040 needed in reply to 57ringo, 12-30-2006 18:47:05
G/MAN wrote this on another thread: "Before pulling the rockshaft housing, make absolutely sure that the leak is not coming from that swivel fitting. That"s a relatively common leak-point on Deeres. I"ve removed many rockshaft housings from small-frame (like your 4440) and large-frame Deeres."
Have you seen them cracked where I"m talking about?
