620 intake manifold gasket
Craig T
12-30-2006 17:57:33
The last month we have been struggling to get our 620 to run right. Since we're International people it always sounds like it's missing but I'll leave that topic for another day. Anyway today while we were attempting the 4th carb adjustment in 2 days we saw fire coming out of the manifold gasket, turns out it was shot and whoever replaced it 20 years ago didn't even scrape the paint off the manifold before they put it on. I doubt I'll get the new gaskets on before I have to go back to school on Wed. Well I hope this solved our problems.
John T
12-31-2006 06:50:34
 Re: 620 intake manifold gasket in reply to Craig T, 12-30-2006 17:57:33
Craig, It may well (probably is) be necessary to either get a whole new manifold or at least have a machine shop plane/machine yours down smooth where it mates to the head and have the head done likewise as Glen pointed out or else any new gasket will soon blow due to the unevenness and pits and wear on one or other of the manifold to head surfaces which MUST be flat n smooth n even n true to ever hold a gasket. I chased n cleaned all the head bolt threads n used new grade 8 bolts doped with anti sieze when I put a new manifold n gasket on my 620 n she held fine. Its a big n not cheap (if you need a new manifold) procedure but once done right it will last another 40 years.
best wishes
John T
Glen in TX
12-30-2006 18:29:28
Paint on there probably isn't going to matter one bit unless really thick but pitted rusted untrue surfaces of the manifold and head will let it still leak. If manifold is burnt out inside or in between intake and exhaust where it can't seal good that could be part of or the cause of the missing.
