Brakes on a 41 B
caleb
12-30-2006 17:28:50
Thinking about getting into the brakes on the B and was wondering what kind of a job its going to be. The left brake is very weak and the right is a tiny bit better. Any pointers will be greatly appreciated. Caleb
Kurt_JDB
12-30-2006 18:09:03
 Re: Brakes on a 41 B in reply to caleb, 12-30-2006 17:28:50
Caleb
The brakes are pretty easy to work on. A very straightforward job. If you have the service manual, it is all explained pretty well. The brake assemblies are removed from the tractor to service. Remove three bolts, and they should slide right out. You have to remove the pinion gear from the end of the brake shaft before you can separate the drum/shaft from the housing. You might want to backoff on the shoe adjuster before you remove the assemblies from the tractor as this will make it easier to remove the drum/shaft.
After you get it apart and cleaned up, you should be able to see what you need. Post back with what you find.
One problem with that model brake, is the shafts are smaller diameter than later models, and they tend to get gauled up where they bear on the bushings.
Kurt
