1937 unstyled Model A
Dennis Gleespen
12-30-2006 10:22:06
I am considering buying a 1937 unstyled Model A John Deere tractor. I want to store it in my garage and have a concern about it fitting through the garage door. The tractor has 12.4 - 36 rear wheels and 5.50 - 16 front tires. Does anyone know the exact height of the tractor from the ground to the top of the highest stack ( muffler or breather ). How easy are they to remove? I would greatly appreciate any help.
BUDD
12-31-2006 06:04:23
 Re: 1937 unstyled Model A in reply to Dennis Gleespen, 12-30-2006 10:22:06
My 49 "A" fits into my garage with 7 foot door.
BUDD
Ben.So.Tex
12-30-2006 16:07:01
Get a tape and check it out to get the height from ground to top of steering wheel and intake and exhaust. If it dosen,t fit, Now you have an excuse to build a work shop..And park your car/pickup in the garage like it was built for and keep the Mrs. happy....
Chances R
12-30-2006 14:16:15
Just let you know that I have a friend that backed his unstyled A into a garage once and got his head pinched between the garage and the steering wheel. He stopped the tractor in time, but you got to be careful.
Danes Dad
12-30-2006 12:30:01
Dennis, I got the exact same deal. Only a 1936, mine is in the garage now getting worked on. When Dane and I pushed it in I had about one half inch from exhaust to door frame. I have 7' high garge door jambs, clear. I hope you get it and can have as much fun as I am fixin her up. -Tom
jeremy in NE
12-30-2006 11:44:36
I dont know the exact height, but my cousins will fit in a garage door with an 8 foot high opening. I would not recommend taking the bolts in and out of the exhaust stack as that may lead to broken bolts or worse due to the heat. Either way they are fun to mess around with.
Steve Lehman
12-30-2006 10:51:39
Don't know for sure what how tall the tractor is, but it should make it inside a garage door with the stacks removed. Both of them are bolted on with 4 bolts, so they should come off easily.
