7520 with IVT. tranny
CD in Mn.
12-29-2006 20:21:57
Hi all just wondering if anybody had any pros/cons on a new 7520 with the IVT. tranny.? The tractor would be used for a 8 row planter and a 500 bu. grain cart. I was also wondering has anybody went on the gold key tour at Waterloo? is it worth the trip or not? Thanks for any feedback.
tsmith1499
12-30-2006 20:55:30
 Re: 7520 with IVT. tranny in reply to CD in Mn., 12-29-2006 20:21:57
If you do buy one, make sure the dealer goes through and explains how everything works. Deere has found that there are alot of guys out there not using the tractor to their maximum benefit because the dealer did not explain well enough how the trans works in conjunction with everything else. Tom
Brian 720
12-30-2006 18:13:12
We have a 7520 IVT and a 7929 IVT They are both nice tractors, and the 7920 is the cadillac of tractors. The 7520 is used on a 750 drill, tomatoe harvester and a harrow gator, along with a tomatoe sprayer, the IVT is the best thing for running a harvester and spraying as you simply zero in on the speed you want while letting the PTO run at the speed it needs to. The 7920 is used on a 12 row planter, tomatoe sprayer, and grain cart. They are both very fuel efficient on fuel, a we have a 7510 16 speed power quad that will only run a harvester for about 8 hours on a tank of fuel where the 7520 will go almost 12 hours. The 7920 has planted 400 acres of corn on a tank of fuel also. As for the gold key tour I have been on two and would strongly recommend you go, it is worth it. The people at the factory treat you very well and you learn things about your tractor you will never know. We learned the 7520 has the wiring harness installed at the factory for a loader joystick and we traded it on a new 7520 this year. The dealer tried to sell it to a guy who wanted a loader and he didn't know it already had the harness, the guy was not going to spend $3500 on a wiring harness so he bought another tractor and seen me later telling me he would have bought it if he knew it had the harness.
Brent H
12-30-2006 04:41:10
Our dealership has a couple IVT tractors out. One is a 7920 and the other is an 8430. The 7920 has turned into this farmer's favorite tractor, he uses it for everything from planting with a 12 row planter to baling hay. The farmer with the 8430 is equally as happy, he pulls a 24 row planter, and says the IVT is really great in his vegetable operation where very low speed, but lots of PTO horsepower is needed. I have driven one, and it takes some getting used to, but looks like it would be great once you learn how to run it.
Woodbeef
12-30-2006 03:37:03
Is that tractor not built in Germany with the ZF ECCOM II shiftless tranny?
zf
12-30-2006 07:31:39
 Re: 7520 with IVT. tranny in reply to Woodbeef, 12-30-2006 03:37:03
Nope, the tractor is built in Waterloo. The IVT in the 7520 is a ZF transmission
