1947 D final drive
Tom/Idaho
12-29-2006 17:55:35
How do you remove the retainer (D 2456 R) from the quill (AD 1276R)? I have a new felt seal (D 2455 R) to put in. I can't get a new retainer (no longer available) and can't seem to get the old one out without destroying it. I realize bearing spacer (D 2454 R) may be somehow keeping the retainer from coming off the axle shaft.
Anyone have any ideas? Thanks for any assistance. Tom/Idaho
Glen in TX
12-30-2006 08:09:45
 Styled D axle breakdown in reply to Tom/Idaho, 12-29-2006 17:55:35
Usually need the axle completely torn down to keep from ruining the retainers and can pull them out then. For the D933R velumoid washers you can use orings or lead washers too. JD use to supply soft rubber hose packing to replace those washers too. third party image
Glen in TX
12-30-2006 07:14:17
 Re: 1947 D final drive in reply to Tom/Idaho, 12-29-2006 17:55:35
The D2454R spacer has to come off to change out the felt seal in retainer. If it was all leaking real bad you are wasting time just trying to change the outside felt and the inner seal needs to be replaced too and yes the whole axle housing has to come off to do that. Change it now or live with leaks on your new paint and barn floor later. If you can't get the inner seal AD1250R that subbed to AD1251R just get some CR 29906 Chicago Rawhide seals. For retainers you might try Greg at [email protected] as he might have NOS or replacements? You must not have manuals either? D parts catalog PC659 and the I & T JD-4 shop manual will help a lot. YT and others sell the I & T and Ed 812-537-4622 or JD 800-522-7448 have other manuals.
Tom/Idaho
12-30-2006 10:12:56
 Re: 1947 D final drive in reply to Glen in TX, 12-30-2006 07:14:17
Thanks for responding. I have an owners manual and a parts book. Service manual is on it's way. When I drained the oil I got about 12 gallons of oil and some water. I know it holds about 7 gallons so the excess oil probably went out past the seal. I have a new seal (inner) and could only get a new felt for the outside retainer. I doubt that it will leak anymore once I put the right amount of oil in. But, like you said I don't want it leaking on the new paint. I will probably go ahead and change the inner seal just to be on the safe side. Thanks again, Tom/Idaho
Glen in TX
12-30-2006 13:24:57
 Re: 1947 D final drive in reply to Tom/Idaho, 12-30-2006 10:12:56
Yes about 6 1/2" deep of oil or about 7 gallons if you have the large 41 tooth rear axle sprockets. The 41 tooth ones almost touch the back side of case with top pan off. If you have 35 tooth rear gears you need about 8 gallons of oil and 10 gallons with the smaller 28 tooth gears. They even made some 22 tooth gears for the unstyled Ds but don't show those for styled D and you would think it would take 12 gallons with those. Those retainers were hard to find 25 years ago and harder to find now. Several other advertisers for NOS and reproduction parts you might try for the retainers also.
