730D with square widefront wont adjust???
dieselman
12-29-2006 09:55:19
how do i get the bolts out of the square tube they wont budge they are like frozen. we have sprayed that must for rust stuff and also hit on them with a chunk of wood and a 8lb maul.. help i need it widened... thanks
Ten-Twenty
12-29-2006 12:32:35
 Re: 730D with square widefront wont adjust??? in reply to dieselman, 12-29-2006 09:55:19
dieselman,
Your troubles are just beginning if you think it is just the bolts that are "frozen" or rusted in place. Once you get the bolts out, you will find that the knees will not move as well. You will need LOTS of heat, penetrant, and PATIENCE. Do a search on this forum for adjusting/
freeing wide fronts. There will be a wealth of info. Also, go to johnnypopper.com and read through the advice given to the fellow that is freeing up the knees on his JD "G" wide front. All of the advice given will apply to your situation as well.
