John Deere AR Radiator?
Jason Varnum
12-25-1999 21:00:14
I Just recently Tore apart the radiator off of my Styled AR John Deere and have just sandblasted the upper and lower cast iron halves from the radiator. I am now debating on how to paint or seal the inside potions to keep them from rusting. I was thinking about throwing on a coat of gas tank sealer only to the inside portions of the cast iron. Does anyone have any better suggestions on what I should do to the inside, paint? Sealer? If paint what kind? Hardner? NEED OPINIONS. Feel free to E-Mail me at [email protected]
Gman
12-26-1999 04:12:15
 Re: John Deere AR Radiator? in reply to Jason Varnum, 12-25-1999 21:00:14
Jason on my pullin G I used a good Industrial epoxy paint on the inside of block. I don't know how it will hold up,time will tell.I'm going to use the same stuff for the gas tank also.Gman
MikeH(Tx)
12-26-1999 05:06:09
 Re: Re: John Deere AR Radiator? in reply to Gman, 12-26-1999 04:12:15
I can't answer Jason's question, but I would advise against painting the inside of your gas tank with anything other than tank sealer. It is easy to do it right, why use paint? Over time, gasoline WILL soften paint.
I bought the sealer that I use from "The Shop" in California, from an ad in Green Magazine. However, I have seen the same stuff advertised in many restoration related magazines.
Spokerd1
12-26-1999 06:10:07
 Re: Re: Re: John Deere AR Radiator? in reply to MikeH(Tx), 12-26-1999 05:06:09
I am like MikeH, I would not paint the inside of the fuel tank other than the special sealer for it. Now as for painting the Radiator tank. Don't paint it either The paint will come off and plug the tubes. It will also cut down on your cooling capacity. The top and bottom tanks do disberse some heat and you paint the inside and that will cut down the heat transfer. For now you could coat the tank with End Rust untill you get it together and it will not hurt the cooling. (inside of the tank only)
mark
12-26-1999 06:52:49
 Re: Re: Re: Re: John Deere AR Radiator? in reply to Spokerd1, 12-26-1999 06:10:07
also if you paint the radiator core, there is a special black to use. It also helps to disperse the heat.
