36 B Pushrod Tubes
CalJim
12-28-2006 20:15:42
Hello,
Rebuilding a 36 B, got the head back from machine
shop, all new valve components, resurface, etc.
Should I replace pushrod tubes? They look o.k. ,
not corroded or loose, etc. As a general rule, how often should they be re-
placed? Replacing them seems a little tricky but not too
bad if you know what you're doing. Your knowledge and advice are greatly appreciated. CalJim
DickD
12-29-2006 09:38:34
 Re: 36 B Pushrod Tubes in reply to CalJim, 12-28-2006 20:15:42
CalJim; One thing I forgot to mention. These tubes drive out from the rocker arm side, and the new ones are slightly smller on one end which naturally goes in first when installing.
Duane Larson
12-29-2006 09:08:31
If it helps, they are $20.35 ea and you need 4. I would look carefully at the condition before I decide.
DRL
12-29-2006 19:03:28
 Re: 36 B Pushrod Tubes in reply to Duane Larson, 12-29-2006 09:08:31
Don't have the numbers of a U/S B, but just ordered a pair for my '38 A from John Deere and they were $5.25 each.
Duane Larson
12-29-2006 19:25:47
 Re: 36 B Pushrod Tubes in reply to DRL, 12-29-2006 19:03:28
DRL,
AA1615R, push rod tubes for unsA show up as $5.78 on jdparts from my dealer - I thought he was about 10% higher. Don't have a clue why unsB tubes, AB1284R, are so high... Guess I'll order some unsA tubes to have on hand.
Mike M
12-30-2006 05:34:11
 Re: 36 B Pushrod Tubes in reply to Duane Larson, 12-29-2006 19:25:47
Wonder if they raised the price on those B tubes getting ready to discontinue them ? companies do this alot as they can write them off at the HIGH prices.
JDAOS
12-29-2006 06:36:43
Scratch the end of a tube to see if they are Brass, if they are someone has already replaced the originals and you should be good to go.
John T
12-29-2006 06:25:09
Jim, Since the heads already off and had all that work done, NO WAY would I out her all back together with the old tubes. All you gotta do is use the correct sized driver to drive the old ones out, put the new ones in the freezer the night before to shrink them down, and drive them in. That beats waiting until the old ones eventually leak then having to do all that work again right??
John T
Mike M
12-29-2006 04:28:37
I would for sure do it now before it is on the tractor. It will be easier. I think there is a real good chance after being cleaned up at the machine shop they will leak as it may of removed some of the last 60 ? years of crud that sealed them. At least that's what I figured happened to mine. It took a year or more for them to let loose and seep.What a mess that makes in the oil !I think (hope) I caught mine before it ruined the engine and bearings. I had some trouble getting the new ones to seal as the holes in my head were different sizes looked due to poor tolerances from when made new.I ended up smearing some JB Weld on them before installing them for a sealer.
DickD
12-28-2006 22:50:55
CalJim; If it were my tractor, I would definitely install new tubes while I had it apart. If they have never been changed, it's a good bet they are getting thin, and it would be so easy to do it now. I'm sure once you get it all together, and painted, you sure won't want to disassemble it for something you can fix now at a nominal price. Especially something as easy to do as this. MTC
